It is currently Sun Aug 24, 2025 3:18 pm
PostPosted: Sat May 18, 2013 11:23 pm
First name: David
Last Name: Morris
City: McKinney
I need some help. I tried brushing black shellac (dewaxed Zinsser stuff with Transtint mixed in) over the whole body without taping off the binding. Then I tried scraping the color off the binding. I've heard people do this, yeah? But I suck.
I'm tearing up the binding and taking off color where I don't mean to. I've tried using the scraper normally, and I've tried just going with the corner. I've tried razor blades too. What the heck am I supposed to be doing here?
Thanks.
David Morris
PostPosted: Sun May 19, 2013 12:11 am
Don't give up. Its called "skill", and it rarely happens along perfectly the first time through... Keep at it, and do-over as many times as it takes.
It'll go a lot easier on the next one. Remember, if it were easy, everyone would be doing it.....
PostPosted: Sun May 19, 2013 7:42 am
First name: Richard
Last Name: Trottier
State: Massachusetts
Hi,
If your bindings are at all porous you have to seal them. Apply two coats of blonde shellac to the bindings before applying anything colored:filler, finish or stain.
Good luck... DT
PostPosted: Sun May 19, 2013 8:42 am
Lots of good tips. Seal (at least the binding) first, don't wait too long, etc.
I use a razor with a hook turned (easy) and a pull stroke, with the thumbnail dragging along the edge acting as the "fence" (...you can get very accurate this way, moving in a few thou' at a time). Another tip, If I know I'll be colouring then scraping back, is to have a thin black purfling line innermost. That way you have .020" margin of error when scraping and the inside binding edge will always look sharp.
Milton, ON
PostPosted: Sun May 19, 2013 3:42 pm
First name: David
Last Name: Morris
City: McKinney
Ok, I was doing this wrong. Thanks for pointing me in the right direction. At least I can have a do-over on this one.
David Morris
Users browsing this forum: doncaparker and 14 guests
